Naca 0012 Cd Test
Old   December 8, 2010, 12:33
Default Naca 0012 Cd Test
ferranpm is on a distinguished road
Hello people!
I want to test the profile NACA 0012 for differents alfa and compare the results with experimental and XFoil graphics. It should be simple, but my results are not satisfactory:
ro= 1,225 Kg/m^3
Mu_air=1,75*10^5 Kg/(m*s)
D=1
with these Data, i obtain the differents velocities (in m/s):
Re=200K -> vs= 2,8
Re=500k -> vs= 7,102
Re=3M -> vs=42,612
Re=6M -> vs=85,224
For alpha= 0°and different viscosity theories:
RE=6M
Spall. Alm. K-E Stndrd K-w SST Trans.flow X-Foil(=Exper.)
cd 3.31*10^(-2) 6.2*10^(-2) 3.32*10^(-2) 5.08*10^(-3)
RE=1M
cd 2.1*10^(-3) 1.73*10^(-3) 5.4*10^(-3)
RE=200k
Spall. Alm. K-E RNG K-w SST Trs.flow X-Foil(=Exper.)
cd 6.4*10^(-5) 1.5*10^(-4) 3.14*10^(-4) 1.02*10^(-2)
For Low-Re I thought that K-omega sst could be better than K-Epsylon, but I don't see a good result...anywhere (the mesh is good, from the profes.)
Thank you for your help!
Ferran
ferranpm is offline   Reply With Quote
naca 0012
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Problems with flat plate and NACA 0012 Lift/Force Harly FLUENT 0 June 18, 2007 11:02
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
