December 1, 2010, 12:38 |
Periodic BC at inlet/outlet
Stef
Rep Power: 15 |
Is it possible to make an edge be both periodic and velocity inlet, while another is periodic and pressure outlet?
I am modelling a wind tunnel in FLUENT and have introduced a "cut" in the tunnel where two parallel edges are very close to each other. One is a velocity inlet and the other is a pressure outlet. I am now trying to animate my model to see how the temperature changes over time. How can I make the air coming out of the pressure outlet go into the velocity inlet? Please help!! Thanks. |
boundary conditions, inlet, outlet, periodic, wind tunnel |
Periodic boundary condition | Arif | FLUENT | 3 | March 9, 2017 01:18 |
Why can't I make the boundaries periodic? | Alina | FLUENT | 5 | April 12, 2012 14:06 |
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap | Josh | ANSYS Meshing & Geometry | 10 | July 8, 2010 02:39 |
Activate Periodic Conditions | IvanCFD | FLUENT | 3 | May 13, 2010 07:02 |
Periodic B.C or Inlet/Outlet B.C | ar_mofidi | OpenFOAM | 3 | February 27, 2010 03:36 |
