Low temperatures modelling heat pump with source terms |
November 26, 2010, 16:43 |
Ian
I am trying to model an air source heat pump acting as a heat sink for a residential building application. As a very simplified model, I created a box shaped fluid zone and adjusted the source terms (not a porous zone). The heat pump has a capacity of approximately 4kW. The pump performs as I expect but in the fluid zone representing the heat pump I get very low localized air temperatures, down to -10C or lower, while the air outside this region is closer to ambient (20C) temperatures.
Just trying to get a sense if this is reasonable or not. Thanks, -ian |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
heat transfer in porous medium (ground source heat pump) | nms | Phoenics | 3 | February 16, 2010 04:19 |
Point implicit treatment of k-e source terms | andy | Main CFD Forum | 5 | June 9, 2006 11:03 |
heat source problem | John | FLUENT | 1 | April 9, 2003 13:08 |
variable heat source simulation | LI Y | FLUENT | 1 | April 7, 2003 23:46 |
