2D flow calculation around an airfoil
Old   November 24, 2010, 18:19
Default 2D flow calculation around an airfoil
Talay
Talayal is on a distinguished road
I’ve just started learning Fluent and Gambit for my school project. For our term project we have to compute 2d flow around an airfoil section. However I’m having some difficulties choosing between different ways to mesh the domain. Our teacher wants us to use quadratic (preferably square) grid. I searched for some tutorials and papers and found few ways to arrange mesh. However I could not find a way to make all grid square, because of the shape of the profile most of them used arc for inlet edge, as a result, around the foil, grid becomes rhomboid. Is there anyone who can help me with this? Also what is the disadvantage/advantage of using square or rhomboid grid?
Talayal is offline   Reply With Quote
Old   December 3, 2010, 21:40
Cool
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear friend,
For meshing, quadratic mesh is best than others but if there are difficult other mesh is OK.. meshing method is mathematics area.. you can find the reason in it.. but for general, great mesh can be seen by its angle.. sharp angle is bad mesh..
hope it helps
teguhtf
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   December 13, 2012, 16:21
Default area problem
Chaudhary
sajid is on a distinguished road
i want to calculate area of circles which would be used in ansys fluent ....
it is 2d heat exchanger and i have problem how to calculate area of circle in front of flow or which area i have to put in reference value ..
i have confusion whether i have to use area of 2 or 4 circles ???
kindly tell me how to calculate this area or which area i have to put in reference value ??? i have attached the jpeg. file of structure to further explain it ?
waiting for answer...i will be very thankful to you.
what Reference values should I used in fluent to find the area as defaults values are 1 for area,depth and length.
Area=?
Depth=?
sajid is offline   Reply With Quote
2d flow, airfoil
Laminer and turbulant airfoil flow M. Essuri FLUENT 3 November 3, 2006 15:14
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 04:56
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 14:49
Warning 097- AB Siemens 6 November 15, 2004 05:41
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
