Rotor / Stator : Modeling flows with rotating reference frame |
November 23, 2010, 19:07 |
Benjamin
Rep Power: 16 |
Hi everyone!
I try to model the rotation of a cylinder (with roughness:look at the attached picture) inside another cylinder (smooth et non rotating) with the purpose of extracting a frequency spectrum of static pressure on the non rotating cylinder wall. My simulation is 2D and unsteady to record the static pressure change. The record probe will be at a fixed point on the stator wall. I would like to know which model is the most accurate in this case (SRF, MRF, MPM ou SMM) ? Best regards! Benjamin |
November 24, 2010, 02:49 |
Rep Power: 16 |
is this a cfd problem ? is there fluid in the annular region ? how is frequency spectrum analysis relevant to flow simulation ?
November 24, 2010, 04:25 |
Benjamin
Rep Power: 16 |
Yes it's a CFD problem, there is a fluid annular region between cylinders.
It's a frequency spectrum (static pressure) generated by the rotation of 'steps' (on the rotor) in the annular region. |
November 24, 2010, 11:04 |
Benjamin
Rep Power: 16 |
Another view of the geometry.
I try to record the unsteady pressure signal on the outer cylinder (fixed). |
November 25, 2010, 11:35 |
Benjamin
Rep Power: 16 |
Nobody knows how to use the Sliding mesh Model in Fluent? What's the methodology?
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 22:58 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 07:14 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
