divergence of scaled residuals (steady simulation)
Old   November 23, 2010, 08:55
Question divergence of scaled residuals (steady simulation)
Hana Matheislova
hanka is on a distinguished road
Hi everybody,
do you have any suggestions why scaled residuals (mainly continuity) in steady simulation drop at first, but started to grow after ca. 20th iteration? Smaller mesh cells and second order upwind discretisation quite helped, but the trend is the same.
Are these results even relevant?
Thanks for any suggestions or ideas
hanka is offline   Reply With Quote
Old   November 24, 2010, 03:06
siri is on a distinguished road
what flow are you solving for ? Your problem might be due to
- improper BCs
- complicated physics or
- inefficient mesh field
other causes might exist, but could say the above in general
siri is offline   Reply With Quote
Old   November 30, 2010, 05:09
Hana Matheislova
Hi Siri, thanks.
It is a non-spreading fire in an empty cuboidal room. The fire is defined only by energy source (W/m3), which is generated in a cylinder area. There is a door opening (interior) to the next empty cuboidal room, where the walls are pressure outlet. I am interested especially in temperatures in the room and a flow through the door.
The mesh is hexahedral with the same size in the whole domain. If I made the cell size smaller, the residuals got better - increasing of continuity and energy was only very slight (other residuals were nicely decreasing).
I am only a beginner in Fluent (I have more experiences only with CFD programmes specialised to compartment fires), so I am sorry, if my questions are quite stupid or irrelevant...But is it possible to use these results or does this behaviour mean that there is a serious problem? Or what do you think about it in general?
Old   November 30, 2010, 06:16
Hana Matheislova
I have probably detected the main reason: the energy source of the fire is too high. The residuals do not increase if this value is much lower. The problem is, that this simulation should correspond to a real fire test, so the released heat and the fire size can not be changed.
Old   November 30, 2010, 07:07
I don't think that would be a right approach to draw conclusions to your observations. Mass and energy should both get conserved regardless of the magnitudes involved.
Whatever your real test data be, it does not matter. As long as you successfully fed the computer with the right mathematics & physics governing your problem, your residuals MUST converge in all circumstances.
If not, erroreous results will be conveyed. Every CFD user must appreciate the implicit pitfalls such as these while using codes.
Old   November 30, 2010, 07:30
Hana,
I was writing this reply when I read your other post. I submitted a long response, but it didn't get posted unfortunately.
Let me summarize instead brief pointers. I am sure you will appreciate this if you have worked on other CFD codes. As I still suspect the problem lies either in material BCs or equations being solved.
  • Can you check if all fluids, solids/walls are exactly what they should have been?
  • What are you using to solve Continuity equation? How you compute the pressure/density - does it comply to the actual physics - it is very important
  • You may check for the net mass flux thru inlet to outlet. If this is positive, it means mass conservation is violated. Then results mean null even if energy got conserved !
  • Increasing mass residuals can mean many things.. even justifiable in some cases... does your model include species/reactions/combustion kind of stuff ?
Lastly what did you mean by "There is a door opening (interior) to the next empty cuboidal room, where the walls are pressure outlet"
I wonder, why should you bother to model the adjecent room walls at all ? when you are only "interested especially in temperatures in the room and a flow through the door"
Why should you not just define the outlet for the flow at the location of the door opening?
Old   December 16, 2010, 05:45
Hana Matheislova
siri, thank you very much for your detailed reply. First, I was thinking and studying the influence of the adjacent room, which you mentioned in your reply. This is also the reason why I did not reply sooner. It sounds maybe weird, but it has an influence on temperatures and mainly on the flow through the door. If I consider no adjacent room, the flow through the door is not correct.
Now, I will finally check your suggestions...
residuals
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Steady state simulation of a turbine? milos OpenFOAM Running, Solving & CFD 0 November 17, 2009 08:52
divergence in energy residuals swarley FLUENT 2 May 22, 2008 09:09
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
