Setup for Fluent Flux Reports
Old   November 16, 2010, 15:00
Default Setup for Fluent Flux Reports
Jeremy Allen
Jallen13a is on a distinguished road
I'm trying to figure out how to setup a problem so that I can get the correct information in Fluent post-processing.
I have an internal channel that splits into 6 channels. I want to find the mass flow rate in each individual channel using Fluent's flux report. How do I do this properly?
Here is what I tried doing...
1) created surface bodies in each of 6 channels in DesignModeler (these surface bodies were specified as fluids)
2) created named selections for each channel
3) hid the surface bodies
My thinking was that it would be easiest in Fluent if I had named selections for each channel. The problem I had with this approach was failed meshing. The surface bodies split up the fluid body unless I suppressed them, but if I suppressed them then the named selections would no longer upload to ANSYS Meshing.
Does anyone have other suggestions?
Thanks for your time
Jallen13a is offline   Reply With Quote
Old   November 17, 2010, 01:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If you defined each outlet separately, you can get the mass flow rate at each outlet:
Report/Fluxes... with option Mass Flow Rate.
It was before on Fluent 6.3, and maybe it has changed on the actual version
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 17, 2010, 10:13
Jeremy Allen
Thanks for the response max. Right now I don't have the system ending with the 6 channels as outlets. The flow from the 6 channels combine back into one outlet.
I've been able to define an iso-surface to get a velocity contour map of all of the channels. Just can't figure out how to set up the flux reports.
Old   November 17, 2010, 10:21
-mAx-'s Avatar
Maxime Perelli
Use iso-surface to create a cross section on one channel.
Then you should retrieve the massflow rate in Report/Surface Integrals...
Old   November 17, 2010, 10:31
Jeremy Allen
Hmm, I'm not quite sure how to limit the iso-surface. For the time being I just defined a plane (in the x-y plane) and gave the z-coordinate that I wanted it to be at. I'm not at a computer with fluent at the moment. I'll try to figure that out later today.
Old   November 17, 2010, 12:45
Jeremy Allen
I wasn't able to get the iso-surfaces to work to get separate surfaces for each channel.
However I was able to create surfaces by going to surface>plane... and checking bounded and defining the plane by 3 points. I did this for all 6 channels. In the end I had 6 surfaces spanning the cross-section of each channel.
The problem that I then ran into is that flux reports only allow you to calculate the mass flow rate at boundaries and not surfaces. Once again I'm running out of ideas.
Old   November 18, 2010, 02:16
-mAx-'s Avatar
Maxime Perelli
Old   November 18, 2010, 11:32
Jeremy Allen
Of course, Thank you max
flux report, named selections, post-processing
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
Oscillatory mesh motion setup mesh flux ERROR jaswi OpenFOAM Running, Solving & CFD 5 August 23, 2007 05:41
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 09:19
