Charge Transport for Fuel Cell Applications
Old   November 8, 2010, 11:27
Default Charge Transport for Fuel Cell Applications
Jeremy Allen
Jallen13a is on a distinguished road
I'm trying to simulate a fuel cell setup and would like to get current density on the surface of the cell. Is it possible to do this without the fuel cell module? I've only used Fluent for several months now, but I can't find anywhere to set this up (and perhaps it just isn't available or must be set up by the user)
The reaction I'm looking at is the anodic half reaction for a hydrogen cell
H2 + O^2- --> H2O + 2e^-
Thanks for any insight you can offer.
Jallen13a is offline   Reply With Quote
Old   April 3, 2012, 06:32
karthik
kitrax is on a distinguished road
I am doing something very similar if not the same. I am modelling a 3-D cell, with channel, GDL and CL (initially investigating the anode). I model the GDL and CL as continuum's in gambit and I wrote a simple (very simple) UDF to define a source (sink if you want to be pedantic) term using the general N = I/2F, for an initial approximation, this is technically a rate of reaction at the boundary.
I entered in the standard reaction under the define section of the program and then called the source term I wrote after compiling it in the boundary conditions under the catalyst layer domain. Initially the model didnt work so I switched off the reaction term and just used my UDF, now I get decent results (I also had to play around with the solver settings).
I hope this helps, I am not sure about some of the details though as I am also still a new masters student and only have been working with fluent for a few months.
kitrax is offline   Reply With Quote
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
