particle - wall collision ( urgent)
Old   November 8, 2010, 01:47
Default particle - wall collision ( urgent)
Angie
Angeline is on a distinguished road
hi guys,
I need some assistance on eulerian two fluid model for gas- solid flow . Is it possible to define the coeffcient of restitution for wall - particle collsion. I am not finding that in fluent. Its a different value than particle-partice collsion.
Angeline is offline   Reply With Quote
Old   November 8, 2010, 05:17
J. Lipowsky
jlipow is on a distinguished road
if you're using to the dense discrete particle model, the restitution coefficients of the discrete phase are accessible under
Boundary Conditions -> [BC][Phase: mixture] -> Edit... -> DPM tab
jlipow
jlipow is offline   Reply With Quote
Old   November 9, 2010, 02:06
Angie
but in eulerian-eulerian approach , how can i specify this???
please reply anyone , its urgent...
Thanks in advance.........
Old   November 9, 2010, 03:34
J. Lipowsky
I don't think that a restitution coefficient can be set in pure Euler/Euler, as the solid phase is not fully modeled as a collective of discrete particles in this approach.
Either you'll have to work with the specularity coefficient found under:Boundary Conditions -> [BC][Phase: phase-2] -> Edit... -> Momentum tab
or you'll have to switch to another model which resolves the solid phase as discrete particles (DPM/DDPM).
jlipow
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 03:05
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
