Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7
Like Tree2Likes
Old   April 1, 2016, 13:54
Lucky
Originally Posted by cyrusIII View Post
Anybody can tell me what is Exceed11 used for? I am new in CFD. I know (correct me if I am wrong) Gambit is probably for geometry and Fluent for solving and meshing but what is Exceed for?
Fluent is for solving (newer versions of Fluent also do meshing).
Gambit is for meshing (it doesn't do CAD). It's advertised by Fluent as a pre-processor.
Exceed is a windows software that allows you to run X-applications in Windows OS, basically it allows a Unix-like window application to run on the Windows OX. It's common to use Exceed for applications developed or natively run in Unix that are later ported to windows while keeping the same X server usage.
Basically, you need Exceed to run Gambit on Windows (or another way to run x-applications).
Old   April 2, 2016, 00:03
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Windows lacks X-Server component of gui and that is provided by exceed our any other x-server emulators. I slightly disagree with LuckyTran on two things. One, Gambit is CAD and messing combined. Yes, you can use it to start from scratch. Though it will require skill to generate a "very" complicated model. Second, x-server is not required to port applications from Linux to Windows; Fluent is an example. It is required to display graphics of the tools that use x-server components, Gambit is an example, other is desktop of Linux itself or Mac. However, I'd not recommend Gambit. It is more than 10 years old and is much less capable as compared to current tools, primarily because it is 32 bit application. It crashes a lot. If you wish to use ANSYS tools, prefer Spaceclaim and Meshing or DM and messing.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 2, 2016, 13:01
saha2122 is on a distinguished road
Send a message via Yahoo to saha2122
Hi anybody
exceed is used just for Gambit running. in other words if you don't install exceed on your computer, Gambit doesn't work ever!
saha2122 is offline   Reply With Quote
Old   April 2, 2016, 13:10
Hi anybody
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Force Field - Vibrating Immerse Cantilever Problem - Fluent 6.3 herger FLUENT 0 June 27, 2010 20:50
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 11:49
Gambit 6.3 problems with Exceed Anonymous FLUENT 1 June 15, 2006 03:23
