Using pressure outlet BC
Old   November 5, 2010, 15:57
Question Using pressure outlet BC
shreyansh
Shreyansh is on a distinguished road
Hi all,
I am using VOF model in fluent 2d and am studying the flow from a jet at different angles on a surface. The surface is in the form of wall (single line) BC. I give pressure inlet for jet inlet and the surrounding domain boundaries are pressure outlet BC set at atmospheric pressure. Now,the jet after it flows over the wall surface leaves the domain ie. crosses the pressure outlet Boundary at a pressure above atmospheric. From the different fluent runs i have realized that fluent tends to give pressure value between the atmospheric pressure and the actual pressure for the flow.
To fix this problem and to obtain the actual pressure in the flow, I teid to mix pressure outlet BC with outlet and Fluent does not allow to do it. So please suggest some other way to get the actual flow pressure for the flow aver the wall surface, without changing the ambient pressure as atmospheric.
Shreyansh is offline   Reply With Quote
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Pressure Outlet setting CoG STAR-CCM+ 4 June 9, 2010 22:47
what actually is the 'zero pressure outlet b. c.' hwe001 CFX 4 June 7, 2010 16:22
Pressure Drop in outlet Vent Abdul FLUENT 2 October 28, 2008 13:13
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 18:39
