November 1, 2010, 15:37 |
Constant volume Combustion
Iltesham
Rep Power: 16 |
I am new to Fluent and i want to simulate Constant Volume (BOMB) Combustion of a Fuel-air mixture. There is no inlet, no outlet. Just a contant volume chamber filled with fuel-air mixture and then there is ignition at one of the walls. As the flame propagates the charge is converted to burned gas and eventually the flame extinguishes. I want to study the heat flux to the walls due to this combustion. I was trying to use CHEMKIN-CFD module in Fluent, but i am really struggling to set up the problem. Can any body help me here please. Is CHEMKIN-CFD the right module for this kind of problem. thanks, Iltesham. |
November 2, 2010, 16:13 |
Iltesham
Rep Power: 16 |
Can any body atleast provide me or point out If there is any Tutorial available for this kind of problems with (Fluent 12).
Or atleast tutorials for some problem similar to this one. Shall be grateful. thanks, Iltesham. |
November 3, 2010, 12:26 |
Rep Power: 17 |
That is interesting. First, how do you combine the CHEMKIN and FLUENT? As I see, it is not easy to couple CHEMKIN mechanism with Fluent. |
November 4, 2010, 11:36 |
Iltesham
Rep Power: 16 |
There is a module in Fluent 12.1 called "CHEMKIN-CFD" it solves both flow equations and chemical kinetic equations.
November 5, 2010, 09:40 |
#5 | |
anonym
Rep Power: 17 |
November 5, 2010, 11:53 |
Iltesham
Rep Power: 16 |
Is there a tutorial available for the spark model..
Can you please forward me one, if you have.. WIll be greatful. thanks, Iltesham |
November 9, 2010, 17:23 |
Iltesham
Rep Power: 16 |
Can any body please provide me with some tutorial with the spark model.
October 24, 2024, 06:51 |
Shahbaz Sholapure
Rep Power: 2 |
Were you able to do it?
chemkin-cfd, const vol combustion |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
combustion in internal combustion engine | George | Main CFD Forum | 0 | September 7, 2006 15:41 |
