Moving Meshes or Rotating Refrence frame is suitable for Rotating Blades? |
October 27, 2010, 14:16 |
Arash
Rep Power: 17 |
Dear all,
could you tell me if i want to rotate 2 blades of wind turbine in 1 zone which solution is appropriate? Rotating Reference frame or Sliding meshes (Moving meshes) I attached a schematic of my blades and domain Thanks a lot in advance. |
March 19, 2011, 03:49 |
yagizb
Rep Power: 15 |
you can use both of them,
but i can recommend single rotating reference frame, it makes the problem easy, |
March 20, 2011, 11:52 |
Rep Power: 16 |
I suggest you to use Moving Mesh method and solve the unsteady problem. Solution with rotating reference frame is a steady one, so depends by the position of your blades
March 21, 2011, 02:07 |
Rep Power: 17 |
For my thesis on a Savonius VAWT i used sliding mesh for 2d and 3d simulations and the results were very good.Sliding mesh is also very simple to use.Regards.
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 22:58 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 07:14 |
Rotating Reference frame | Ketan | FLUENT | 0 | May 25, 2007 12:58 |
Rotating Domain,Blades St frame or rotating? | Pankaj | CFX | 1 | May 5, 2007 08:06 |
Moving reference frame | CFD_boy | FLUENT | 6 | April 20, 2006 12:39 |
