material property
Old   October 26, 2010, 23:04
Default material property
raymond
wlt_1985 is on a distinguished road
I would like to define two physical properties for a fluid. I am using the material panel to define the properties with defining the user defined database. One is in polynomial form and I define it correctly with help of user guide. Unfortunately, another one is in out of the forms provided by Fluent. What should I do to define this physical property?
wlt_1985 is offline   Reply With Quote
Old   October 27, 2010, 04:05
bob12 is on a distinguished road
i don't understand what you mean in this point: Unfortunately, another one is in out of the forms provided by Fluent.
i think that you want create a new material? so you can change the value and save with another name at this point fluent ask a confirm of operation. you click yes and you have a new matiarial with your physical property.
bob12 is offline   Reply With Quote
Old   October 27, 2010, 05:44
raymond
Yes. I would like to create new material. Hence, I need to define the properties of material. There are a lot of methods in Fluent used for definition, like polynomial, constant etc. Unfortunately, the method I need for properties definition is not available in Fluent. What should I do for the best?
Thanks for help.
Old   October 29, 2010, 03:51
i think that you implemented the property of material with a user definiction function. if you see the last term of windows menu are an udf.
Old   October 29, 2010, 07:28
Kristian Etienne Einarsrud
KristianEtienne is on a distinguished road
If you look in section 2.3.16 in the UDF manual you will find a description of the DEFINE_PROPERTY macro with which you can implement (more or less) any form or dependency for your material. There are also a few examples in this section, if you are unfamiliar with UDF programming.
Cheers!
KristianEtienne is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Liquefied natural gas_LNG material property help! songxguan CFX 2 November 14, 2008 10:34
material property Tomik FLUENT 1 January 20, 2007 01:20
material property llnudt FLUENT 1 December 7, 2006 04:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
