Problem of negative volume.......Please help
Old   October 25, 2010, 01:52
Default Problem of negative volume.......Please help
Nimmy Thankom Philip
nims is on a distinguished road
Hello all,
I am trying to simulate the oscillatory motion of a vertical cylinder partially submerged in a tank ( can be rectangular or circular).I am using the following features of fluent.
1. VOF model
2. Define_CG_motion udf to give the oscillatory motion
3. K-epsilon model for Turbulence modelling.
Now i couldnt find a proper mesh for the problem.
I tried with a rectangular domain splitting it to 4 quaters. But when the mesh size is too small its causing global courant number value very high. When i solve this problem sometimes negative volume problem coming.
Can anybody help me find a proper meshing....?
nims is offline   Reply With Quote
Old   October 25, 2010, 03:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
negative volumes are linked with your MDM parameters
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 31, 2010, 01:57
Hi max,
I am using spring smoothing method for mesh update.The below are the parameters which i am using.
Spring Constant Factor 1
Boundary Node relaxation 1
Convergence tolerance 0.001
Number of iterations 20
I tried using the layering method also
But for both the cases the non positive volumes exists after 1 oscillation of the cylinder. can u help me out further..
Old   November 2, 2010, 03:07
-mAx-'s Avatar
Maxime Perelli
Are you able to see where are those neagtive cells?
Check also if your displacement isn't too high in comparion with your cell height (if yes then reduce your timestep)
negative element volume (CFX-10.0) CFDworker CFX 8 September 27, 2011 19:16
blockMesh error ... balkrishna OpenFOAM Pre-Processing 0 August 17, 2010 03:39
[ICEM] negative mesh volume problem (icem-cfd/cfx) adam2008 ANSYS Meshing & Geometry 5 April 16, 2010 13:21
Negative volume problem in Two-way FSI coupling fred CFX 3 August 16, 2006 11:03
Negative volume in ICEM CFD hagupta CFX 4 June 30, 2006 07:20
