October 19, 2010, 09:47 |
multiple simulation in FLUENT in Batch mode
Rep Power: 16 |
Its just to help you guys. I was trying to write a journal to run 3 simulations in Que on batch mode on Supercomputer but had been experiencing problem, then Max suggested me to check the journal by writing the command on your Console Window and it worked.
To run FLUENT in the batch mode you can use this journal file. it will run 3 simulations one by one (Transient Case) file/rcd/Folder Location/File name.cas grid/check solve/dual-time-iterate Time Step Iteration/time step file/wcd File Name yes file/rcd/etesh_ncsa/ncsa_simple/ncsa_simple.cas grid/check solve/dual-time-iterate 7500 80 file/wcd ncsa_simple yes file/rcd/etesh_ncsa/ncsa_sa/ncsa_sa.cas grid/check solve/dual-time-iterate 7500 80 file/wcd ncsa_sa yes exit yes For Steady case just use solve/iterate 1000 (number of iterations) Last edited by jola; January 5, 2012 at 12:02. |
Running FLUENT in batch mode for Windows OS | Jake Lee | FLUENT | 7 | June 29, 2016 09:38 |
Batch issues to get results from a transient simulation | aero | ANSYS | 0 | November 10, 2009 07:32 |
Fluent - batch file - avoiding questions | fluentguy | FLUENT | 1 | June 14, 2009 17:57 |
fluent stops batch mode on error | Ralf Schmidt | FLUENT | 1 | March 1, 2008 11:35 |
Help!! Why I can't run fluent in batch mode? | Cindy Jones | FLUENT | 0 | April 9, 2003 00:39 |
