October 13, 2010, 09:39 |
use several interpreted UDFs
Eddie
Rep Power: 16 |
Hi
I prepared some UDF files as source terms for velocity, turbulence kinetic energy, and Turbulent dissipation rate and I interpreted them successfully. But I see only the last interpreted UDF in the graphical panel of the source term. Please help me to solve this problem. Thanks |
October 13, 2010, 16:17 |
User_CFD
Rep Power: 16 |
A why didn't you write profiles(of velocity, turbulence kinetic energy, and turbulent dissipation rate...) in one UDF?
October 16, 2010, 04:29 |
How...
Eddie
Rep Power: 16 |
1. How can I define that which dependent variable ( i, e, U, V, k or epsilon) should be processed? Would you tell me how IF commands in the code?
2. If I want to use separate UDF , for example another UDF for energy source term, how can I see all of interpreted UDF in the graphical panel? Thanks in advance |
graphical panel, udf |
problem using property udfs in parallel mode | EllenW | Fluent UDF and Scheme Programming | 5 | July 10, 2009 05:31 |
Unsteady and Flux UDFs for UDSs | tom | FLUENT | 0 | February 13, 2009 11:27 |
error in interpreted udf's for two macro | Asghari | FLUENT | 0 | August 7, 2006 03:10 |
DEFINE_CG_MOTION Interpreted or Compiled? | Aussie Shane | FLUENT | 0 | April 20, 2006 05:50 |
Experimental Repository for UDFs, Journal Files and Scheme Scripts | Jonas Larsson | FLUENT | 0 | March 5, 2000 16:36 |
