Opening a .jou file in FLUENT
Old   October 11, 2010, 17:58
Default Opening a .jou file in FLUENT
Martin
Martin_D is on a distinguished road
Greetenigs to all.
Let me describe you my problem. I have to analize an airflow over a profile. I've got a .jou file where my coordinates are specified. I am a total beginner in using the FLUENT software. I'm looking for some hints on how to setup the problem. I've tried to open the file in fluent but the program displays me the following: vertex invalid command , for every coordinate that is set in the .jou file.
The next question is linked to setting up a 2D mesh for FLUENT. I've been looking through some threads in the forum and it seems to me that you can generate a mesh in ICEM CFD, if I'm wrong pleas let me know. In another post I've read that you can also design a 2D profile (editing the properties) in design modeler and then proceed to the mesher. My question is how can I import (if it is even possible) the coordinates from my you file to DM or ICEM CFD, basically how to setup the problem in the design an meshing area?
Thank you for your answers.
Greetings.
Martin_D is offline   Reply With Quote
Old   October 11, 2010, 22:52
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
jou is a command file, not that only include geometry information. Extract the point information from the jou file, and import to ICEM CFD, you can build your model based on them.
In ICEM CFD, link the coordinates with lines to create a domain, and then create mesh on it either with block strategy or mesh strategy.
rikio is offline   Reply With Quote
Old   October 12, 2010, 06:32
Martin
I don't know how to extract the .jou, which program do I use?
Old   October 12, 2010, 07:26
Max
coglione is on a distinguished road
It seems to me that this is an journal file for Gambit, the now retired preprocessor of FLUENT before Ansys took over. As long as you don't have this software on your computer your .jou files won't be of any use.
cheers
coglione is offline   Reply With Quote
Old   October 12, 2010, 07:40
Martin
After looking through all tutorials thats what I thought... thank you all for the information.
Old   October 12, 2010, 11:15
Martin
Is there anyway that I could import those points to design modeler-setting the analysis from 3D to 2D, like it is described in the following tutorial, except the tutorial is flow past a flat plate:
http://www.pdftop.com/view/aHR0cDovL...xheWVyLnBkZg==
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 09:10
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
