Launching Fluent: Segmentation fault
Old   October 11, 2010, 11:43
Default Launching Fluent: Segmentation fault
Reine Granström
gravis is on a distinguished road
Hi all,
I have recently upgraded my Linux OS from Centos 4 to 5.5. I installed ANSYS products (CFX & Fluent) and while CFX works fine, I am having problems when trying to launch Fluent. Both CFX and Fluent worked fine with Centos 4.
The error message I get when starting Fluent can be seen in the uploaded picture. The number 7435 in the is random each time I launch Fluent. I get the same problem both for serial and parallel.
Regardless of the products not being tested on Centos (I know CFX is not and I assume Fluent is not either), hopefully someone could give me some advice here. I know problems should be expected when using untested Linux distros, but I hope someone can point me in the right direction since I have no idea where to start here.
Thanks.
gravis is offline   Reply With Quote
Old   October 12, 2010, 04:56
Reine Granström
Unfortunately I did not properly search through the forum. I found this thread, which solved the problem for me:
http://www.cfd-online.com/Forums/flu...p-problem.html
My hostname was not connected to my IP adress in the hosts file, and that was the problem.
So anyway, if anyone would be interested Fluent seems to work fine with Centos 5.5 so far.
Old   October 22, 2010, 17:05
Basharat
elbasharat is on a distinguished road
please you have still issue or resolved?
Rgds
Martin
elbasharat is offline   Reply With Quote
Old   October 23, 2010, 10:41
Default Working
Reine Granström
Fluent still seems to work fine with CentOS 5.5.
Segmentation fault - new enthalpy equation SilPaut OpenFOAM 0 August 25, 2010 12:55
Grid resolution - Segmentation fault George Main CFD Forum 0 September 4, 2007 18:38
KIVA and Segmentation Fault Felix Main CFD Forum 2 January 18, 2006 02:24
Segmentation Fault Victor Main CFD Forum 5 April 5, 2005 09:09
Segmentation Fault Prateep Chatterjee FLUENT 1 May 29, 2000 11:47
