rotating propeller in stationary baffled vessel
Old   October 14, 2010, 09:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't know what you want to compute...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 14, 2010, 12:49
anonymous
cfd_confuse is on a distinguished road
Ohh.. i would need to calculate the velocity contour within the mixing tank and would like to use the MRF method to solve the problem. Can i know what are the boundary conditions? Thank you for your help so far!
cfd_confuse is offline   Reply With Quote
Old   October 15, 2010, 02:19
-mAx-'s Avatar
Maxime Perelli
Did you checked tutorial 9? (Using MRF)
Old   October 15, 2010, 16:25
anonymous
Hi Max, i did try out tutorial 9 and apply the same boundary condition as given. But my solution did not converge and it diverge after 1000 iteration. Skewness of the cell is also < 0.6.. so i guess there must be some conditions that i did not set, that had cause the solution to diverge. Please enlighten. Thanks in advance
Old   October 18, 2010, 01:59
-mAx-'s Avatar
Maxime Perelli
Check display of velocity contour and pressure --> are they in agreement with your expectations?
Check also mass conservation (report/ mass-flow)
Old   March 29, 2011, 16:09
raymond
wlt_1985 is on a distinguished road
Originally Posted by -mAx- View Post
so I received your file.
Do followings:
*delete volume2
*create cylinder (height 0.2 / radius 1=radius 2=0.04 / Axis Location Positive Z)
*split volume1 with the cylinder (volume4)
*delete volume5 (solid) --> should be already deleted (volume2) but it's early this morning, don't want to investigate )
here we are, you have 2 regions: rotor and stator.
*copy volume1 with translation (0.1 0 0) (it generates volume 5), delete volume1
*move copied volume5 with translation (-0.1 0 0)
* The 2 volumes are now disconnected.
Apply interfaces (one for each volume)
Hi, max. For the splitting step, is there any effect if different sizes of cylinders have been used? The sizes of cylinders have been attached as follow. Please have a look and thanks for help.
wlt_1985 is offline   Reply With Quote
Old   March 30, 2011, 02:19
-mAx-'s Avatar
Maxime Perelli
no influence
But I would extrude the inner cylinder through the whole domain (along your revolution axis)
Old   March 30, 2011, 02:22
raymond
no influence
thanks for help, max.
Rotating propeller in a finite freestream velocity asma CFX 9 January 7, 2014 07:14
Counter rotating propeller (propfan) Ball FLUENT 0 August 13, 2008 17:14
Rotating Propeller Nolin FLUENT 1 September 7, 2006 00:07
propeller rotating at zero inflow velocity Ammu FLUENT 1 July 23, 2005 14:36
Solid particles in a rotating vessel with 5.7.1 Sandeep CFX 0 May 17, 2005 11:54
