October 6, 2010, 04:15 |
Symmetry surface
novice
Rep Power: 17 |
Hi All,
I want to simulate a flow through an openchannel to get the headloss values. Should i consider a two phase model or define the freesurface as symmetry surface and simulate a single phase model??? Will there be any difference in the pressure calculations if i consider a symmetry surface in place of the free surface of the open channel. Thanks in advance |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
