How to define rotational direction for wind turbine
Old   September 30, 2010, 09:28
Default How to define rotational direction for wind turbine
tom
caohan is on a distinguished road
Hi all,
Does somebody can tell me how to define the rotational direction of a wind turbine. I use sliding mesh to simulation the rotation, the axis of wind turbine is defined as (1,0,0). My question is that how to define rotational-axis direction of rotational volume wihch contains the wind turbine, is (1,0,0) or (-1,0,0). because when I set wind turbine and rotational volume with the same direction, I can't see the helical wake.
Regrads
Han
caohan is offline   Reply With Quote
Old   October 4, 2010, 03:11
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I would say you should set the rotationnal speed with respect of rotation axis
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 19, 2012, 11:54
Default draw a wind turbine
Issaoui Ines
omtango is on a distinguished road
Hi everybody
I am doing a CFD simulation of a wind turbine (Rutland GW530) and I'm struggling because i can't draw it until now on gambit
so please ,
there's anyone can help me ??
I have juste one more month to finish my projet
so pleaaaaase
omtango is offline   Reply With Quote
Old   April 20, 2012, 09:14
Default Rutland GW530
scipy's Avatar
Alex Pasic
scipy is on a distinguished road
Send a message via Skype™ to scipy
Do you have the turbine blade modeled in 3D already? Something like SolidWorks/Catia/Pro-Engineer?
scipy is offline   Reply With Quote
Old   October 9, 2012, 23:50
Default turbina fransis
alfredo
fredyyd is on a distinguished road
ola quetal estoy realizando una simulacion en fluent en 2d pero no puedo indicar el sentido de giro del flujo de aire dentro de mi turbina si alguien puede ayudarme seria de mucha ayuda gracias...
fredyyd is offline   Reply With Quote
Old   October 10, 2012, 06:43
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
