bubble diameter distribution
Old   September 27, 2010, 08:03
Default bubble diameter distribution
EMRAH DENIZ
emrahdeniz is on a distinguished road
I am working on water-air flow thorugh horizontal channel. I use euler-euler mixture model for that. I want to give a bubble diameter distribution along radial direction instead of inserting a constant diameter value in the related menu. ( phases > secondary phase > diameter )
Below you can find the trial udf I wrote for that. y is the radial axis. I have the half of the channel thus y has the range between -r and +r, where r is the radius of the channel.
#include "udf.h"
DEFINE_PROPERTY(bubble_diameter,c,t)
real y;
real diameter= P_DIAM(c,t);
if (y < 0)
diameter = 0.001;
else
diameter = 0.005;
return diameter ;
I can interprate the udf successfully but after I initialize, it gives me the following error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
I think I have problems in the udf. I will be glad if someone could tell me what mistake I am doing.
Thanks in advance...
emrahdeniz is offline   Reply With Quote
bubble diameter, e-e mixture model
DPM diameter mass distribution Wouter FLUENT 5 May 23, 2019 03:18
Bubble Diameter Santi FLUENT 3 March 4, 2010 11:56
Bubble diameter in Gas-solid Fluidized Bed Wee FLUENT 0 April 28, 2008 00:04
About bubble diameter setting in multiphase flow tchllc FLUENT 5 August 22, 2007 10:47
About bubble size distribution simulation tchllc FLUENT 0 August 12, 2007 05:07
