No grid adaptation
Old   September 21, 2010, 07:42
Default No grid adaptation
Pim van Ooij
Pimmie80 is on a distinguished road
I'm doing a steady simulation with prescribed velocity values at every node of the velocity-inlet boundary. After convergence, less nodes are found on the inlet boundary and the prescribed velocity values have altered slighly, resulting in lower Reynolds number than I put in the simulation, while I want the inlet to remain exactly as I prescribed it. I think this is due to the mesh adaptation that FLUENT performs automatically. My question therefore is: Can I switch off all adaptation options in FLUENT? No Refinening or coarsening, not on boundaries, no gradient adaptation, etc. I tried to switch everything under Adapt off, but nothing worked so far. Thanks for your help!
Pimmie80 is offline   Reply With Quote
Old   September 21, 2010, 09:35
Neil
Trev is on a distinguished road
Look in the fluent manual how to adapt using a mask so you can prescribe which regions can or can't be refined/coarsened. Turn off dynamic mesh adaption and do it manually so you have more control over the mesh.
Neil
Trev is offline   Reply With Quote
grid partition AND dynamic mesh adaptation !!!!!!! bohis FLUENT 0 January 16, 2009 04:00
grid adaptation for better convergence. co2 FLUENT 9 April 2, 2004 15:08
Grid Adaptation Suresh FLUENT 0 October 15, 2003 14:18
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
floating point error during grid adaptation Nurul Murad FLUENT 2 September 5, 2001 20:15
