Uncoupled calculation for discrete phase?
Old   September 20, 2010, 16:11
Default Uncoupled calculation for discrete phase?
ljp
ljp is on a distinguished road
Hi all,
I'm trying to simulate a liquid spray problem. as a start, I want to inject a single stream of water droplets into a gas field and calculate the trajectory using uncoupled method (the droplets do not have impact on the gas field).
What I did was: at the "Discrete phase model" panel, I didn't select the "Interaction with Continuous phase", but selected the "Unsteady particle tracking" and entered the relevant parameters. I defined the injection and started running. Then after some time, when I tried to display the particle tracks, I found the domain is empty, does not have any particles in it! I don't know where I made mistakes. Could anyone please point out what might be the problem? or tell me the correct procedure of performing uncoupled calculation?
Also, at the "display particle tracks" panel, in the particle variables list there is a variable "particle Weber number". I didn't find its definition in the manual (I want to check whether it's defined the same way as what I know from the literature). Does anyone know its definition? Thanks a lot!!
ljp
ljp is offline   Reply With Quote
Old   September 21, 2010, 08:07
sreenivasa rao gubba
sreerao is on a distinguished road
Hi
Try steady particles, and check particle trackings, it should work for you.
Sreerao
sreerao is offline   Reply With Quote
Old   September 21, 2010, 12:16
ljp
Hi Sreerao, thank you for your reply. I tried using steady particles and I got them in the domain! but since I tried to see how the droplets breakup in the gas field, I turned on the breakup model, then the unsteady particle tracking was automatically selected, and the droplets are lost again. (the total no. of particles is reported to be zero). Does that mean that the uncoupled calculation only works for steady particle tracking? and the uncoupled calculation cannot be used to study droplet breakup?
Thanks a lot!
ljp
discrete phase modeling-coupled or uncoupled? MDinc FLUENT 3 March 22, 2011 08:16
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 13:53
Warning 097- AB Siemens 6 November 15, 2004 05:41
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 08:21
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
