Quarter Burner mesh with periosic condition
Old   September 14, 2010, 06:18
Default Quarter Burner mesh with periosic condition
Sam
SamCanuck is on a distinguished road
I have a 90deg periodic wedge with small holes for air inlets surrounding a burner set to species transport of carbon-monoxide mixture. I created the mesh in ICEMCFD. This is the error:
> iter continuity x-velocity y-velocity z-velocity energy k epsilon o2 co2 co h2o time/iter
# Divergence detected in AMG solver: pressure correction -> Turning off correction scaling!
# Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps!
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 376 cells
Divergence detected in AMG solver: k
Divergence detected in AMG solver: species-0
Divergence detected in AMG solver: species-1
Divergence detected in AMG solver: species-2
Divergence detected in AMG solver: species-3
Divergence detected in AMG solver: temperature
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Error: floating point exception
Error Object: #f
I tried going to 1st order discretization and even switching to just air, but no dice. Could I please get some sort of suggestion on what may help?
Sam
SamCanuck is offline   Reply With Quote
Old   August 31, 2011, 11:00
Default Preesure correction sweep
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I am simulating a twin rotor turbine blade with 180 degree periodic BC. I am simulating at velocities of 7, 10, 15, 20 and 25 m/s. The mesh diverges at 20 and 25 m/s saying divergence detected in AMG solver --> increasing pressure sweep correction,
primtive error at node 0
primtive error at node 1
primtive error at node 2
primtive error at node 3
primtive error at node 4
primtive error at node 5
primtive error at node 6
primtive error at node 7
Initially this error appeared in first few iteration of 20 and 25 m/s but later appeared in other velocity cases as well. I am using default UR factors with Standard pressure and SIMPLE schemes. I also tried with lowering UR factors but didn't work. (However, the mesh was a little bit coarse that time). I have also seen that lowering the UR factors from scratch also diverges the solution.
Any solutions in this regard are welcomed.
Shamoon Jamshed is offline   Reply With Quote
Old   August 31, 2011, 12:34
Sam
Everytime I had a similar error, it was a mesh quality issue. Either there are overlapping nodes (quick and easy) or the mesh density isn't optimal. I am no longer working on CFD so my advice may be rusty.
Good luck,
Sam
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
