problem with heat flux in the wall
Old   September 7, 2010, 05:52
Default problem with heat flux in the wall
gholamghar is on a distinguished road
Hello
I am modeling a plate fin heatsink in fluent,when i apply constant heat flux for example 200 w/m^2 to the base plate there is no heat transfer between the solid heatsink and the fluid flow and there is no difference between inlet and outlet temperatures,but when instead of heat flux i apply "heat generation" to the base plate,in this case there is heat transfer between heatsink and fliud flow, and the temperature of inlet and outflow differs,do you have any idea what is the problem with heat flux?
Thanks
gholamghar is offline   Reply With Quote
Old   September 14, 2010, 08:47
Byron Smith R J
byronsmith is on a distinguished road
hai
when u use a heat flux to a base plate with no heat conduction on the other side, heat flux cannot occur. if you want heat flux at the base plate boundary use negative heat source term to sink the heat and hope that will give you the results
byronsmith is offline   Reply With Quote
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 10:32
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
why the value of wall heat flux is negative? prayskyer CFX 5 September 29, 2006 08:32
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
Wall heat flux drop Rangarajan CFX 6 May 5, 2005 20:02
