Parallel Error in ANSYS FLUENT 12
Like Tree5Likes
Old   March 4, 2014, 20:08
Default use serial processor to open
  #21
Daniel Oliden
Panboy is on a distinguished road
I noticed this happened to me when I imported a mesh from a grid generator besides ICEM.
I had to start FLUENT with the serial processor in order to import the case file from pointwise. Then after that, I would be able to save the case and reopen in FLUENT with parallel processors.
Hope this helps.
Fedor and Traction like this.
Panboy is offline   Reply With Quote
Old   May 19, 2014, 03:49
Default how to fix this problem "unbale to read cmd header"
  #22
Dasiy Wang
wqhcqdx is on a distinguished road
Originally Posted by zeusxx View Post
thank u very much. I solved this problem several months ago. Thank u all the same.
Hi, you said you have solved this problem, can you tell us how? I recently come across this problem and it quite distress me. Thank you for you help
Email: wqhcqdx@163.com
wqhcqdx is offline   Reply With Quote
Old   May 19, 2014, 08:54
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by Kanarya View Post
hi,
I have the same problem...what did you mean with 'open UDM in the DEFINE menu' because I am using in define_mass_transfer function C_UDMI but it doesnt work in parallel...
thanks in advance!!!
He meant that if you have UDMs in your UDF, first, you'd better check if you have defined them in Define menu or not. You might have forgotten to define them before you use them in your UDF. That's all.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 21, 2015, 04:02
rtn htysl
hataysal_e is on a distinguished road
Actually the divergence is strictly related by the dpm injections, for the cases including dpm injections.
If you go on injecting DPM in an unsteady manner, dpm allocates memory and at some point the anlysis crashes. kind of a memory error.
switching of the unsteady dpm can solve the problem, but by this way some accuracy may be lost.
hataysal_e is offline   Reply With Quote
Old   July 16, 2015, 05:42
raj kumar saini's Avatar
Dr. Raj Kumar Saini
raj kumar saini is on a distinguished road
Send a message via Skype™ to raj kumar saini
999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
Have to solved this problem?
raj kumar saini is offline   Reply With Quote
Old   July 17, 2015, 05:40
Dr. Raj Kumar Saini
I always get error message when I using ANSYS FLUENT 12 with a Windows 7 x64 system and ANSYS 12 x64.
unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
job aborted:
rank: node: exit code[: error message]
The Parallel FLUENT process could not be started.
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
SuspendThread failed with error 5 for process 2:627A4F0C-CA4B-4435-B90A-4D110B465C35:'D:\ANSYSI~1\v121\v121\fluent\fluent1 2.1.2\win64\3ddp_node\fl_mpi1212.exe -mport 10.10.10.193:10.10.10.193:49174:0 node -mpiw mpich2 -pic ethernet'
unable to suspend process.
received kill command for a pmi context that doesn't exist: unmatched id = 1
received kill command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
Can anyone help me or provide ideas to fix this problem?
Thank you very much~
Have you solve this problem
job aborted:
job aborted:
ansys 12, fluent, parallel error
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Fluent v6.3.26 better than Ansys v12.1 jemyungcha FLUENT 2 August 25, 2012 00:10
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 16:30
