Fan Boundary Condition OR Fixed Values or Source Terms
Old   September 6, 2010, 05:37
Default Fan Boundary Condition OR Fixed Values or Source Terms
EB
SolarX is on a distinguished road
Dear all,
I’m working on a 3d-problem in which I would like to fixed x-velocity in certain air volume. I'm using Fluent Solver version 5.
In Fluent one can fixed the air volume rate by means of mass (kg/m^3*s) using the Source Terms or via Fixed Values using the X Velocity (m/s). What is the purpose of these tools and their differences?
Because when I do fixed the x-velocity (using segregated solver implicit) then I can't run the simulation because of divergence or floating point errors! I don't understand, since the solver is chosen properly according to the Fluent Manual. How can I use this tool in this problem? When I use mass via Source term then nothing is happening.
Secondly, in order to fixe the volume rate I think Fan Boundary condition can be used. However not much information in using this tool I could found. Can somebody provide me how to use this tool in combination with a pressure inlet and pressure outlet boundary condition?
Thank you in advance.
Kind regards
SolarX is offline   Reply With Quote
Old   June 9, 2011, 05:13
WhityWhite is on a distinguished road
Good day!
If this problem is still important you can use source of momentum to solve it.
WhityWhite is offline   Reply With Quote
fan, fixed values, fixed velocity, fluent, source terms
Fan Boundary Condition Vijay FLUENT 0 February 13, 2009 15:45
pressure jump in fan boundary condition Vijay FLUENT 0 February 12, 2009 19:19
Fan Boundary condition Quocbao FLUENT 0 November 11, 2008 04:17
Problems with Fan boundary condition Nish FLUENT 2 August 27, 2004 19:27
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
