Supersonic flow over a flat plate and a blunt body.
Old   August 31, 2010, 17:35
Default Supersonic flow over a flat plate and a blunt body.
Shushank Ravi Arora
Maddy is on a distinguished road
Hi everyone,
I have to do a flow over a flat plate as well as blunt body. i am planning to run the above for three different Mach numbers 2,3 and 4. i have to concentrate on the boundary layer generated over these bodies. The following parameters are to be compared with experimental results - Skin friction coefficient, Mach number, momentum thickness, displacement thickness, boundary layer thickness, shock strength and separation length.
How to i do this using fluent?
Where do i get the data from and how do i validate it?
looking forward to results
Thank you all in advance
Maddy is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
supersonic flow over flat plate varunjain89 Main CFD Forum 1 March 23, 2010 09:26
supersonic flow over a flat plate Vishwajeet Main CFD Forum 1 April 15, 2007 23:00
Supersonic flow over flat plate - best model Chris Rand FLUENT 4 October 3, 2000 07:58
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
