how to plot attack angle along with impeller span direction at leading edge |
August 31, 2010, 15:47 |
wild
Rep Power: 17 |
hello, folks,
I got stuck on how to plot attack angle at impeller's leading edge along span direction through FLUENT. can anybody here give me a hint? thanks a lot or if I simplify this question, given that I know inlet angle distribution, how can I plot inlet relative flow angles? in this case once I can figure out what's the relative flow angle, I will be able to know attack angle. |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
How to creat the impeller leading edge | Jasmine | ANSYS Meshing & Geometry | 0 | June 13, 2009 03:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 09:18 |
Plot drag coeff,lift coeff VS angle of attack | John | FLUENT | 2 | August 29, 2003 14:06 |
