April 24, 2014, 04:00 |
#21 | |
Rep Power: 12 |
I did everything you specified above I only have two clarifications. 1.) I sometime get a negative k=permeability because when I plot DeltaP vs Velocity it gives me an equation with a -Bx. My question is, can I use this (-) Value of k as input? if not please give me a hint on how to remedy this problem. 2.) To get C2 and k you have to use L=Thickness. My question is what thickness to use?, the thickness of the screen which you got the experimental data from ,(P vs V), or the representative porous media's thickness used in the solver (I some times use thick Porous media for ease of meshing) Thanks. -will |
August 19, 2014, 02:32 |
Details of Porous Media
#22 |
Jeeban Poudel
Rep Power: 12 |
I am trying to understand and operate a porous media in which the void fraction is arranged in random order. Whenever I select the system as laminar, the flow is laminar and even when I select it to be turbulent, the flow is laminar. So, what are the factors we need to consider (it is very complicated to consider all points) to simulate the random arrangement of the void fraction? Further which parameters are normally selected and avoided while considering the porous media. |
October 5, 2014, 16:16 |
porous media
#23 |
usamaraad
Rep Power: 12 |
hi for all
I need to know the steps of build up a porous media by using fluent program I need for these steps too much so I wish form any one who can present the assistance to support me please |
July 20, 2015, 15:48 |
#24 |
mohammadreza
Rep Power: 11 |
Hi every body
I don't know how determine initial velocity for the flow in porous media. Thank you for time and consideration. Best regards |
July 21, 2015, 07:29 |
#25 |
Mayur Bhandari
Rep Power: 11 |
Hello Rupak Banerji,
In your first message you said about tutorial number 8. Which series of tutorial you are solving? can you share? |
December 28, 2017, 08:50 |
modelling porous surface
#26 |
vasu
Rep Power: 9 |
Hey friends
how do i model a porous surface in ansys fluent? can i make a wall surface porous need help thanks in advance |
December 28, 2017, 15:22 |
#27 |
i man
Rep Power: 13 |
December 28, 2017, 21:11 |
#28 |
vasu
Rep Power: 9 |
January 4, 2018, 04:00 |
#29 |
tahir
Rep Power: 16 |
hi Nelly.
you said that pressure drop can be calculated from CFD. I am working on combustion of heptane gas through porous medium. In this case how can i calculate the porous coefficient. Your help is really needed. |
October 4, 2019, 14:32 |
Porous media
#30 |
Somesh
Rep Power: 7 |
The Velocity in porous media shows the same as inlet pipe. Is their any difference in velocity in porous media and the velocity in empty pipe??
October 4, 2019, 14:35 |
Porous media
#31 |
Somesh
Rep Power: 7 |
Is their velocity difference in porous media and the empty pipe. I doing simulation in ansys. Using physical velocity but i didnt se the difference in velocity
gambit, porous |
modeling the fluid flow in porous media by Fluent | Mohsen Nazari | FLUENT | 5 | April 26, 2019 05:45 |
Modeling heat transfer through a porous media | harimighty | FLUENT | 3 | July 23, 2016 06:11 |
Discrete phase modeling on porous media | magnounibo | FLUENT | 0 | April 9, 2009 09:18 |
Modeling thin perforated plates as porous media | Mike | FLUENT | 0 | August 21, 2007 05:16 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
