August 26, 2010, 06:04 |
Chimney
Tomek
Rep Power: 16 |
I want to model chimney effect. I used pressure boundary conditions, pressure inlet and outlet is O [Pa], operating pressure 101325 [Pa], density - ideal gas, gravity - 9,81 (axis y) I think the level of pressure in my chimney is wrong, is to small than should be. For example for density in chimney 0,68 the pressure below atmospheric should be near 25 [Pa], i have only 12 [Pa], i used species transport because i want to model how many air will be injected to the chimney but for this case for start i want to know how model simple case when the density is known. Thanks for your answer
August 26, 2010, 07:56 |
xrs333
Rep Power: 17 |
Hi, Tomek,
Would you give a description of the computational domain? And I'd like to remind you of the fact that the pressure in FLUENT do not include the hydrostatic head. |
August 27, 2010, 05:29 |
Tomek
Rep Power: 16 |
Thanks for your answer. Can you give me your email adress. I will send you my computational domain with boundary conditions. My subject it is to show possiblity of FLUENT and one of the subject is chimney and chimney effect
September 1, 2010, 05:36 |
Svetlin Filipov
Rep Power: 17 |
Please refer to the UG and TM before saying this.... if you try solving VOF case you will find that pressure can be taken into account...
chimney |
How to model "chimney effect" using Fluent? | Feidao Li | FLUENT | 10 | January 14, 2010 10:43 |
Chimney | Aminop | FLUENT | 6 | May 7, 2008 11:04 |
how to model geometry of plume from chimney in 3D | dave | FLUENT | 1 | July 19, 2005 17:34 |
Heat transfer through a chimney | ocy | FLUENT | 1 | January 24, 2005 23:16 |
Heat transfer in a chimney.....HELP NEEDED..... | abong | FLUENT | 0 | December 2, 2004 02:06 |
