mesh generation for supersonic flow followed by freestream
Old   August 26, 2010, 01:50
Exclamation mesh generation for supersonic flow followed by freestream
padhu
padmanathan is on a distinguished road
Hi all,
I am trying to simulate supersonic swirling flow in a pipe to analyze the flow characteristics inside and after the exit of a pipe. i'm getting error while creating face mesh, 'coz the pipe exit edge is shared by free stream. So, How to choose boundary or create mesh.
I have chosen 2D axisymmetric flow, and the flow inside pipe is considered as supersonic and exit to atmosphere.
Herewith i Have attached geometry, which gives you the idea of the problem!
Thanks in advance,
padhu
padmanathan is offline   Reply With Quote
Old   August 26, 2010, 03:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't have experience on supersonic swirling flow, but regarding the modeling side, if the surfaces are connected (surfaces separated on your red line), then gambit should set the edge as internal (default). Just don't set this edge as special BC.
Now if your surfaces have 2 different physics, you can define them as separated continuum (fuid domains)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 26, 2010, 04:44
padhu
thank you max,
If two faces sharing the same edge, how we can set boundary?, 'coz particular edge is outlet to pipe and inlet to freestream.
once again Thanks ,
padhu
Old   August 26, 2010, 05:18
-mAx-'s Avatar
Maxime Perelli
go to Boundary condition panel and select the edge as entity.
But once again, I wouldn't set this edge as special boundary. Just let it, it will be assimiled as interior.
Setting it as outlet won't be correct since you have behind it a meshed domain where your fluid is free to move
Old   August 30, 2010, 07:48
padhu
Thankyou Max,
I didn't find the option entity in both gambit as well as in fluent to set boundary in the edge .
excuse me for the delayed reply.
padhu
Old   September 14, 2010, 04:01
-mAx-'s Avatar
Maxime Perelli
excuse me for the more delayed reply (back from holidays)
you can find what you want in gambit: Zone/specify Boundary Types
Old   September 14, 2010, 08:53
padhu
Thank you, Max. I will try and reply soon.
freestream, mesh generation, supersonic flow
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
need reference for structured mesh generation cfduser03 Main CFD Forum 3 September 7, 2009 10:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
3-d elliptic generation mesh Gang Sun Main CFD Forum 5 September 16, 1998 01:24
