*Urgent*Pressure Inlet Bundary Condition Error*Urgent* |
August 23, 2010, 15:16 |
farhad
Rep Power: 16 |
Dear all
I have a question about reversed flow error in pressure inlet boundary condition. I am modeling flow of water in a simple channel (only one faze). I have 4 boundary conditions, velocity inlet, pressure inlet for free surface, wall and pressure outlet for outlet. I know that I can use symmetry boundary instead of pressure inlet for free surface, but I want to know why the results of velocity filed of these two cases are different each others? Let me to ask my question in another way, can I use pressure-inlet boundary condition for free surface of water or not? If I can please explain for me why the flow is reversed and how I can fix this error? I hope some nice persons help me. Best Regards, Farhad |
August 23, 2010, 23:17 |
xrs333
Rep Power: 17 |
Hi, Farhad,
Free surface can not be simulated by pressure inlet. A problem fall into the category of open channel flow, a multiphase flow, if it involves free surface of two phases. In FLUENT, VOF model can be used for this. |
August 24, 2010, 15:50 |
farhad
Rep Power: 16 |
Hi Xrs333
Thanks a lot for your reply. According to your reply I mention some points and questions, please answer them: 1- I know that the VOF model can model free surface, but I do not want to model the free surface. I want modeling only region under free surface. The interface of two faze is not important for me (My free surface has not any fluctuation). 2- In fact I want to model the sedimentation in a sedimentation tank (settling tank). I have mixture of water and sand in a tank and there is a free surface at above. My main problem is that which boundary conditions must be applied for it? Is pressure inlet done? 3- Can I use Eulerian model for 3 faze (water, sand and air) or must be used a two faze model and a boundary conditions for free surface? 4- Is it possible using pressure inlet for free surface and 2 faze instead of modeling 3 faze in Eulerian model? And Finally 5- Is Eulerian model able to predict the interface of water and air or the VOF model is the single model for this target? Best Pleasure, |
August 24, 2010, 21:53 |
xrs333
Rep Power: 17 |
In this case wall boudary with zero shear stress can be used to simulate free surface. As to the Eulerian multiphase model I am not familiar with it.
August 25, 2010, 04:36 |
farhad
Rep Power: 16 |
Thanks Xrs333.
VOF Inlet condition | Rizwan | FLUENT | 15 | July 5, 2018 17:33 |
How to use a solution as an inlet boundary condition in another problem in fluent | geryes | FLUENT | 0 | February 25, 2010 17:32 |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 12:14 |
outlet to inlet boundary condition | assighna | CFX | 1 | May 11, 2007 00:36 |
inlet and outlet boundary condition of pump | Thammasak | CFX | 0 | February 9, 2004 14:02 |
