porous media
Old   August 23, 2010, 11:08
Default porous media
sarah
sarah l is on a distinguished road
hello every body!
I am working on a project about heat transfer in packed bed of spheres, and my problem is why can I modeling it to fluent because we have heat generation in each of spheres!
sarah l is offline   Reply With Quote
Old   September 3, 2010, 19:09
Zdeth
zdeth is on a distinguished road
Sarah, have you figured this out yet? I'm trying to model ~heat exchangers in the porous media, I'd like to get a fixed temp. of the 'media'
zdeth is offline   Reply With Quote
Old   September 5, 2010, 00:23
sarah
no yet, I'm doing on a kind of reactor !
fixed temp! so It is good to modeling, it is steady state and the bounary condition is determinded.
Old   September 6, 2010, 07:17
Exclamation @above
masters
manohar is on a distinguished road
even my problem is very similar with your ones..my aim is to calculate the pressue drop when a fluid flows through porous zone..i have given the values of inertial resistance and viscous resistance also ..i got the answer of 2.5e+4 pressure drop with porosity 1..but i want the pressure drop at porosity 0.5 ..if i give the porosity as 0.5..i m getting the same pressure drop..i have written the udf also ..still i m not getting the correct answer for different values of porosity except at 1..can any 1 pls answer my problem..thanks in advance
manohar is offline   Reply With Quote
Old   September 12, 2010, 22:38
chétan
coalgas is on a distinguished road
Hello Everyone,
anyone did tried Euler Granular approach?? as it offers treatment to two different phases rather than Porous formulation.
coalgas is offline   Reply With Quote
Old   September 13, 2010, 07:52
mehulkumar is on a distinguished road
Hi.. Manohar,
Please check the equation to calculate pressure drop !!
Also refer the momentum eqn with porosity for the question of porosity.
Mail me if still not got any hint.
Regards,
Mehulkumar
patel.mehulkumar.l@gmail.com
mehulkumar is offline   Reply With Quote
Old   April 22, 2011, 14:04
Default Linking porosity and the resistance
Neil Duffy
neilduffy1024 is on a distinguished road
Manohar,
The inertial and viscous resistances are not actually linked to the porosity, well in Fluents eyes anyhow. I'm not fully sure I understand what you are doing but if the porosity is constant throughout the simulation, you just have to enter resistances specific to each porosity. I am not very familiar with flow through a porous medium but I think that a linear relationship is a common assumption, i.e. resistance directly proportional to porosity.
If your porosity is being changed during the simulation, which requires a DEFINE_PROFILE UDF, then simply store the porosity in user-defined memory (UDM) and write a second DEFINE_PROFILE UDF for your resistances which calls the porosity you just stored. This way you can link resistance and porosity.
Neil
neilduffy1024 is offline   Reply With Quote
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 10:43
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 12:11
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 06:52
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
