urgent help for under relaxation parameters
Old   August 18, 2010, 12:40
Default urgent help for under relaxation parameters
Mansureh is on a distinguished road
Hi everybody
How can I change under relaxation parameters to get converged solution when I simulate a multiple reference frames(MRF) case and residuals fluctuate. I mean which parameter should be changed and how much?
thanks for any help
Mansureh is offline   Reply With Quote
Old   August 18, 2010, 13:04
xrs333
xrs333 is on a distinguished road
Hi, Mansureh,
If the calculation is diverging, reducing under relaxation may alleviate the the problem, but may impede the converging speed. And the reason underlies is you incorrect building of the model or initial values for iteration. So, my advice is better model and better initial values. And now that you are using MRF, use solution strategies for MRF.
xrs333 is offline   Reply With Quote
Old   August 18, 2010, 14:35
Post Need more help
Dear friend, xrs333
Thanks very much for replying. could you tell me how can I find information about MRF strategies,please? can I find it in Fluent help documents? let me explain more about my geometry. It consists of several coaxial annuluses that two of interior ones rotate in relatively high rotational speed. gas flow inters from the outermost annulus and exits from the innermost one. I want to obtain gas pressure drop from the inlet to outlet, but the result is lower than that must be. I use RNG k-epsilon turbulence model. could you help me about this?
thanks
Relaxation and convergence sammi Phoenics 0 March 20, 2008 04:32
Relaxation and Solver Parameters norbinou Siemens 3 September 25, 2007 02:38
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 15:37
Relaxation Parameters. J. Keays Main CFD Forum 3 October 16, 2000 14:42
Relaxation Parameters. J. Keays FLUENT 1 October 16, 2000 03:00
