suction boundary condition for a synthetic jet
Old   August 18, 2010, 08:48
Default suction boundary condition for a synthetic jet
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi
I am trying to model suction over an airfoil in fluent and gambit.
but i encountered some problems that i can not find the solutions for since 2 weeks ago.
first:: i have read many articles that model continous suction or suction using a
synthetic jet.
all of the articles give us the suction velocity ,but when i choose the outer
boundary as pressure far field ,i see some warnings. some body tolds me that
i have to use the pressure outlet boundary condition for suction hole...
but i can not calculate the pressure for my low renolds number model...
in other words when i am trying to re-do an earlier numerical work in fluent that
used velocity inlet for suction,i also have tobe able to do it..
2; the drag coefficient is negative in nearly all cases and the lift coefficient
has a big variation with the exact value..and sometimes has a negative value.
3.i have modeled more than 7 different cases in gambit with differen meshes.
i do not know where do the problems come from?
please answer these questions :
a: which type of mesh is better for modelling a base airfoil and suction-including airfoil..
C-H grid....O-grid....boundary layer mesh or ....
please send me a dbs file of mesh over a base airfoil and a dbs file of mesh over a sutioned
airfoil...
b: please tell me which boundary conditions i have touse in gambit...
pressure far field,symmetry,wall or ...... for a typical C-H grid over airfoil please
express the boundary cond. detailed.
c: which solver and discretization schemes is better to model a base airfoil and
suctioned airfoil.
tell me the appropriate turbulance model and any other things you things is good to
better model an airfoil.
d: to calculatethe darg and lift coefficients in fluent , is it needed to change
the default value of area in refrence value?
elease send me by email useful file(tyrorial,mesh file,dbs file ,case and data file or..)
thatcan help me to do this...thanks
i am ready to send you my works to tell me my faults..
but it isan emergency ..please sooner...
thanks
f:: please answer me,,,,,, i'm stock...
morteza08 is offline   Reply With Quote
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 17:53
