How to explicitly model a heat sink
Old   August 17, 2010, 18:20
Default How to explicitly model a heat sink
Antonio
pandora is on a distinguished road
Hi there
I'm trying to model a relatively simple problem but having some difficulties with how to reformulate it in "fluent terms". Let me put it as simple as possible:
Coolant flowing through circular tube. Both the tube and the coolant have a non-homogeneous internal heat generation (coming from X-Rays). Let's consider the tube adiabatic which means that coolant is releasing all the heat. What I would like to calculate is the radial temperature profile (to later calculate thermal stresses). Since I'm only interested in the radial profile there's no need to actually model the flow throughout the tube (in the axial dimension). We can assume that in the axial cut I want to calculate the T profile the flow is fully developed and that I know the convection coefficient. Is there a way to model this 2D problem with Fluent? Can you define a negative source term in the coolant cell so as to represent a heat sink? If so, and considering that I also have a non-homogeneous heat source in the same cell (from the X-rays) would it be licit to subtract to this non-homogeneous X-Rays heat source the total heat that has to be released (in this case evenly distributed through the fluid cell?). I hope I explained myself!
I would acknowledge any help you could provide me. Thanks in advance
pandora is offline   Reply With Quote
Old   August 18, 2010, 13:36
Antonio
Can someone help me here? Is it that the problem isn't clear? It basically boils down to the following question: Which is the easiest way to calculate the radial T profile on an adiabatic tube with internal heat generation.
2-d, adiabatic, heat sink
Heat Transfer Coefficents in Two Resistance Model Miguel CFX 1 December 8, 2018 18:08
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
How to use Heat Exchanger model? Johnny FLUENT 0 August 9, 2004 08:44
