What is the relation between Static temperature And total temperature?
Old   August 16, 2010, 02:54
Default What is the relation between Static temperature And total temperature?
Subhankar
subhankar_bhandari is on a distinguished road
Hi all,
what is the relation between Static Temperature and total temperature?
Thanks.
subhankar_bhandari is offline   Reply With Quote
Old   August 18, 2010, 15:46
Troy Snyder
tas38 is on a distinguished road
The total or stagnation temperature is the temperature that would exist if a fluid was brought to rest isentropcially. In other words, the total temperature includes the static temperature and an additional component due to the velocity of the fluid. For a perfect gas, the total temperature may be expressed as T_total = T_static + 1/2 * V^2 / (cp), where u is velocity magnitude and cp is specific heat.
tas38 is offline   Reply With Quote
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
static temperature more than total temperature ?? mahesh FLUENT 4 May 18, 2016 07:09
Total temperature and static temperature rogbrito CFX 1 June 21, 2009 19:37
Static and Total Temperature Tomislav FLUENT 4 December 4, 2006 05:59
The static temperature is higher than total temp devy FLUENT 0 March 27, 2003 21:16
