Under Relaxation Factors(URF) in unsteady problem
Old   August 14, 2010, 19:00
Post Under Relaxation Factors(URF) in unsteady problem
Maxmum
Maxmum is on a distinguished road
Dear all,
I am using Fluent calculating unsteady flow field. At first all the URF are set as 0.1 by me, or it is hard to continue. then, when the residual reduces steady, I increase the URF to 0.5, it can also continue fluently. I set Max Iterations/Time Step as 20. The problem is how can I make myself belive that the unsteady flow is the one I want. In other words, how to prove the calculation is convergenced in every time step? also by Residual? I think there must be relationship between URF and Max Iterations/Time Step. But if the Max Iterations/Time Step are set too large, it will be very hard to get a wanted unsteady solution if the cash is big.,Right? Thank you very much and looking forward to your reply.
Best
Maxmum
Maxmum is offline   Reply With Quote
Problem in Reporting Unsteady Particle Fates Nelson FLUENT 0 August 23, 2006 21:24
Postprocess of Fluent for unsteady problem Rana FLUENT 5 August 21, 2006 05:30
SOS: About VOF-Dynamic mesh unsteady problem whpsoft FLUENT 4 May 9, 2006 20:26
unsteady state problem prasad FLUENT 0 April 4, 2002 23:44
Question concerning about unsteady problem.... ghlee Main CFD Forum 6 October 2, 1998 06:36
