Patching a phase
Old   August 14, 2010, 14:31
Default Patching a phase
Khurram
deep_seak is on a distinguished road
Hi, I am trying to patch water phase in a vertical u-tube geometry but its not happening. I want water phase to be patched in the lower portion of the U-tube filling the lower legs to an extent, while air remains on the upper portion. Can anybody give me an idea, how to do it ?
deep_seak is offline   Reply With Quote
Old   August 16, 2010, 03:34
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in your mesher you need to define the volume you need to patch as separated continuum fluid domain.
Then in Fluent after you initialized your whole domain, you can patch the desired fluid region
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 16, 2010, 08:01
JP
srjp is on a distinguished road
Or, you could do it directly in fluent, by creating a region (bounded by minimum and maximum x,y,z coordinates) and then patching that region with the volume fraction of air or water.
To create the region: Adapt > Region
To patch: Solve > Initialize > Patch
srjp is offline   Reply With Quote
Old   August 16, 2010, 09:36
xrs333
xrs333 is on a distinguished road
Agree with Jayaprakash. One word to add:
click on mark button in the Region panel, do not click on Adapt button, then you'll get a register.
xrs333 is offline   Reply With Quote
Old   August 16, 2010, 10:15
Khurram
Hi guys. Thanks alot for your suggestions, i think the problem will be solved after applying them. If any of you guys can reply to the thread named "Heat transfer problem at nucleate boiling" then it would be great because thats a very big problem for me now a days.
Thanks again,
Old   August 17, 2010, 06:14
Ming
boh_tea is on a distinguished road
Hi,may i know does patching a phase to a region only work in multiphase model?
Thanks!
boh_tea is offline   Reply With Quote
fluent, multiphase, patch, phase
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 13:53
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 04:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
