UDF for pressure at outlet
Old   August 12, 2010, 07:19
Default UDF for pressure at outlet
Mireia Ayop
mireis is on a distinguished road
I'm trying to create a UDF function for the pressure at the outlet. I know the mass flow rate and temperature at this point so theoretically my pressure is a function of the velocity at the outlet. Is it possible to implement a UDF function that calculates the pressure as a function of the velocity?
I have tried with this one but Fluent says there is a "parse error".
#include "udf.h"
#define MDOT_OUT 0.000005  /* desired mass flow rate at the outlet  kg/s */
#define S_OUT 0.00000003905707   /* outlet surface in the model where the mass flow rate is MDOT_OUT   m^2 */
#define R 63.32 /* universal constant for gases  J/kg/K */
#define T 300.13 /* temperature  K */
DEFINE_PROFILE(outlet_pressure, thread, nv)
Thread *t;
face_t f;
cell_t c;
real CTE;
real actual_velocity=C_U(c,t);
/* real pressure = C_P(c,t);
CTE=MDOT_OUT*R*T/S_OUT;
begin_f_loop (f,t)
F_PROFILE(f,thread,nv) = CTE/actual_velocity;
end_f_loop (f,t)
Any suggestions would be greatly appreaciated
mireis is offline   Reply With Quote
Old   October 1, 2018, 13:55
Yuehan
wc34071209 is on a distinguished road
have you solved this problem?
wc34071209 is offline   Reply With Quote
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 15:10
ZeroGradient pressure Outlet BC prob (adjustPhi.C) Stylianos OpenFOAM 3 March 23, 2010 13:28
UDF for Pressure outlet condition jubs FLUENT 0 February 8, 2007 05:30
outlet boundary condition neil CFX 1 June 17, 2002 01:57
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 11:44
