August 10, 2010, 11:57 |
Modelling of 2D Wind Turbine Blade (HAWT)
Richard Morris
Rep Power: 16 |
I am relatively new to FLUENT and having difficulty modelling fluid flow over my 2D wind turbine blade geometry.
I see that in FLUENT>Problem Setup>Boundary Conditions, I can select that a particular part be rotating. This seems ideal for me, as I can then set the blade to be moving and adjust wind speed. However, given the geometry that I have, an appropriate axis of rotation would be in the negative direction on the Z axis. Which isn't available to me (I assume because my mesh is 2D). Can you suggest to me how I might be able to let FLUENT know that my blade is rotating. I don't want to do this in 3D. Would it be more accurate to use the vector addiction of the wind speed and the blade speed or would this be completely inaccurate? |
August 11, 2010, 05:18 |
Jouke de Baar
Rep Power: 17 |
I'm afraid this option might not be what you are looking for. Setting a moving wall will only adjust the zero slip boundary condition of the wall, it will not actually move or rotate your geometry. For a rotating geometry you might use a sliding grid. Good luck! |
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 03:53 |
Can I use Turbogrid to mesh a wind turbine blade? | Henry Liu | CFX | 10 | November 10, 2011 06:41 |
Modelling of 2D Wind Turbine Blade (HAWT) | Richeom | FLUENT | 0 | July 29, 2010 12:57 |
Wind Turbine Blade Geometry | SeanieB | Main CFD Forum | 0 | November 27, 2009 11:18 |
Wind Turbine Modelling | Neil Campbell | Main CFD Forum | 1 | November 10, 1998 20:03 |
