July 15, 2010, 13:38 |
Fluent 12 Journal File Problem
Krishan Parmar
Rep Power: 16 |
Hi I have written a journal file in Fluent 12.
My previous journal was in Fluent 6 and I could write: read-case /home/location/gambit.msh But with Fluent 12, I cannot get the syntax right to get locate the file where the mesh is stored. For example, Fluent 12 writes: /file/read-case "gambit.msh" When I change this to : /file/read-case "/home/location/gambit.msh" This does not recognise the path and fails to load the file Any ideas anyone. Thanks in advance Krish |
July 16, 2010, 02:12 |
Maxime Perelli
Rep Power: 41 |
*did you try without "..."
*else start fluent from your working directory (where your mesh file is stored), then you shouldn't have problem any more, since you don't have to specify any path
In memory of my friend Hervé: CFD engineer & freerider |
July 16, 2010, 07:10 |
#3 | |
Krishan Parmar
Rep Power: 16 |
Starting from the working directory is not really an option. I am running an optimization code and moving files to make it work would make the code and output very messy. Thanks for your help Krish |
How to comment a Fluent journal file | Bottenheim | FLUENT | 11 | December 16, 2024 10:54 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
