Fluid structure interaction in Fluent
Old   July 10, 2010, 07:57
Default Fluid structure interaction in Fluent
Hari Prasad is on a distinguished road
My problem involves the walls of a thin shell containing water deforming under pressure. Can this problem be solved using fluid structure interaction methods in Fluent?? Are user defined functions for Fluent available for using a dynamic mesh method for the above problem??
Thanks in advance!!
Hari Prasad is offline   Reply With Quote
Old   July 12, 2010, 11:19
stumpy is on a distinguished road
You need 2-way FSI for this. Either wait for the next release, or use the ANSYS - CFX 2-way FSI coupling.
stumpy is offline   Reply With Quote
Old   July 16, 2010, 04:17
zaheer abbas
zaheer is on a distinguished road
isn't it possible on ansys fluent ( fluid flow 12.1) or it is only done with ansys cfx! waiting for ur reply ...... actually in my case i have done 1-way fsi by coupling ansys 12.1 fluent with static structural but i m don't know how to switch over to 2-way fsi??????????
waiting thanx !
zaheer
zaheer is offline   Reply With Quote
Fluid Structure Interaction fw407 OpenFOAM Running, Solving & CFD 9 February 14, 2013 18:25
FSI fluid structure interaction tutorial chapter 23 davedave121 CFX 4 February 5, 2010 02:40
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 04:40
FLUID STRUCTURE INTERACTION Javier FLUENT 1 October 14, 2004 14:42
Fluid structure interaction tomm FLUENT 2 September 16, 2004 05:33
