Airfoil pitching problem
Old   July 9, 2010, 12:50
Default Airfoil pitching problem
montag dp is on a distinguished road
Hey,
I'm attempting to analyze a 2D airfoil in a pitch-plunge motion. I have done just plunging and now I want to incorporate pitching as well. I'm using a UDF as follows:
#include "udf.h"
DEFINE_CG_MOTION(airfoil, dt, vel, omega, time, dtime)
real plungeampl, pitchampl, w, pi;
pi = 3.14159265;
/* define motion variables */
plungeampl = 0.0254; /* 1-inch plunge amplitude */
pitchampl = 45 * pi / 180; /* 45-degree pitch amplitude */
w = 2 * pi * 25; /* 25 Hz frequency */
/* define airfoil motion */
vel[1] = w * plungeampl * cos(w * time); /* y-component of velocity */
omega[2] = w * pitchampl * cos(w * time); /* z-component of angular velocity */
For some reason I can't see any rotation. Oddly enough, if I switch the angular speed to omega[0] or omega[1] for x or y rotation, it works fine, but that's not what I want to do.
Does anyone have any idea why the z-rotation isn't working?
Regards,
Dan
EDIT: I just realized there's a dedicated UDF programming sub-forum. If a moderator wants to move this there, that's ok.
montag dp is offline   Reply With Quote
Old   July 9, 2010, 13:10
Figured out my own problem. The pitching motion is actually working but for some reason it doesn't show up when I use "display zone motion." It works with "preview mesh motion."
Old   July 16, 2010, 07:17
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi montag,
I would appreciate it if you could answer me a couple of questions:
When defininf a CG motion for pitch through a UDF, where do you define the centre of rotation? inside FLUENT when defining the Zone which is Moving?
Is your UDF for deforming meshes, or did you have domains with sliding interfaces?
Thanks
aerospain is offline   Reply With Quote
Old   July 16, 2010, 09:29
Hi aerospain,
I'm using a dynamic (deforming) mesh. Inside the dynamic mesh menu is an input for CG location. This is the center of rotation. I have been using the 1/4 chord of the airfoil as the center. Then within that menu I select the airfoil as the moving zone and make sure that my UDF shows up in the motion profile selection box.
Old   July 16, 2010, 09:54
aerospain
Thanks for the quick answer montag.
So, coming back to the picture I posted in my first message, can I define a motion for the intermediate subdomain as a moving mesh (which will move the small subdomain along with it) and a CG motion for the small subdomain for it to have a second motion (which is exclusive to it)?
regards
Old   July 16, 2010, 10:12
regards
I don't see the picture...Do you have domains inside each other, and you want the innermost one to move along with the intermediate one, but also have its own motion relative to the intermediate one?
Anyway, I don't know about moving meshes. Maybe someone else could chime in here?
Old   July 16, 2010, 10:16
Default now with picture
aerospain
Sorry about that, I had another post in mind.
Does it explain my problem?
cheers!
Old   July 16, 2010, 14:35
It does, unfortunately I don't really know about the sliding mesh. It seems like it should be possible, though, but you will probably have to define your airfoil motion relative to the global coordinate system and not the coordinate system of the domain it is directly inside.
Old   August 3, 2010, 10:38
Default rotation about z axis
ahmad
almostafa67 is on a distinguished road
HI EVERYBODY...
i'm trying to rotate a small circle about z axis but i faced a problem,in 2 images that i sent u,u can see it,circle has been locked in its end points,how can i tell fluent that i want rotate small cylinder about center of bigger circle
it's kind of u if u think about it and help me out
almostafa67 is offline   Reply With Quote
Old   August 4, 2010, 18:50
aerospain
Originally Posted by almostafa67 View Post
HI EVERYBODY...
Hi almostafa,
1. Could you please explain a bit more your simulation? What "real world" situation are you trying to model?
2. How manu domains have you defined? Just the one shown in the pictures?
Regards
Old   August 5, 2010, 02:49
ahmad
Hi almostafa,
Regards
i want to simulate peristaltic pump(http://www.randolphaustin.com/) and for this i need to rotate small circle about center of bigger circle,almost i could do this but faced a problem that explained befor,could u help me out?
thank you in advance
Old   June 10, 2012, 13:53
srikanth
srikanthgoli is on a distinguished road
Hi Montag,
Can you please post the UDF.
srikanthgoli is offline   Reply With Quote
Old   June 25, 2012, 07:25
srikanth
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Problem Meshing Airfoil erodv OpenFOAM 12 January 11, 2012 18:46
Plunging Airfoil Problem jmo OpenFOAM Running, Solving & CFD 0 May 17, 2010 23:36
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
[FloWorks] Request advice for an airfoil calculation problem Bogey Jammer Main CFD Forum 0 September 29, 2009 18:06
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
