parse error in transient udf
Old   July 5, 2010, 11:32
Default parse error in transient udf
Sarah
spring is on a distinguished road
Hey guys,
when I try to interprete the following transient udf, I always get two parse errors.
Here is my UDF:
#include "udf.h" /* must be at the beginning of every UDF */
/* constants: */
#define R 8. /* inlet radius [mm] (with actual scaling in Fluent applied!) */
#define VFLOW 15. /* effective volume flow [l/min] */
#define POWER 1./7. /* 1/7 power law defining turbulent profile */
#define f 15. /* breathing frequency */
#define tidal 0.5 /* tidal volume */
DEFINE_PROFILE(unsteady_velocity,thread,index)
double PI;
real Umax; /* maximal inlet velocity */
real x[ND_ND]; /* this will hold the position vector every single face centroid */
real r;
real U;
real breath;
face_t f;
real t = CURRENT_TIME;
PI = acos(-1.);
Umax = pow(10.,3.)*VFLOW/PI/pow((R),2.)/49.;
breath = tidal/PI/f*sin(2*PI*f*t);
begin_f_loop(f,thread) /* loops over all faces in the thread passed
in the DEFINE macro argument */
F_CENTROID(x,f,thread);
r = sqrt(pow((1000*x[0]),2.)+pow((1000*x[2]),2.));
U = Umax*pow((1.-r/R),POWER);
if (breath > 0.0)
{F_PROFILE(f,thread,index) = U*breath;}
else
{F_PROFILE(f,thread,index) = 0.0;}
end_f_loop(f,thread)
The errors are in the red lines.
Errors:
Error: \UDFprofile3D_tansient.c: line 26: parse error.
Error: \UDFprofile3D_tansient.c: line 28: parse error.
Error: \UDFprofile3D_tansient.c: line 32: t: undeclared variable
I dont't know how to remove this errors, because I can't find any fault in my udf. But maybe your eyes are better than mine, and you can help me and tell me where my fault is
And I dont' think that's a problem caused be interpreting the UDF, because I've made the right steps:
1. activate "transient" under General
2. and interprete the udf as usual; Define->User Defined->Functions->Interpreted
Thank you very much in advance!
spring
spring is offline   Reply With Quote
Old   July 6, 2010, 07:26
Sarah
I've found my errors. I used the variable f twice: once as a frequence and the second time in the expression face_t f. That's once too much, hehe.
I also forgot to ad an f in the expression F_CENTROID(x,thread) ...
Bye!
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 11:26
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
parse error with interpreting UDF ivanbuz Fluent UDF and Scheme Programming 2 August 13, 2009 19:29
UDF parse error at profile function line Wiggy Fluent UDF and Scheme Programming 1 July 27, 2009 16:59
UDF parse error on line 1 ..... (Unusual) Amit Maha FLUENT 4 June 30, 2006 13:15
