July 5, 2010, 05:48 |
Possible to have <10 surface monitors?
Daniel
Rep Power: 16 |
I'm trying to monitor static pressure on a surface at 19 different points. I have defined these points and set up the first ten monitors without problem. However, each time I define more than ten I get the following message:
"Error: Monitor <name> has not been completely defined. Error: Object: #f" I am working on a university computer so the first thing that sprung to my mind was that this ten-monitor limit may be something built into the academic version of the solver. Any ideas on how I can define all 19 monitors? |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Surface monitors in fluent | Ann | FLUENT | 4 | February 10, 2014 12:36 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
