Pressure Inlet Boundry Condition...
Old   July 3, 2010, 03:52
Default Pressure Inlet Boundry Condition...
Rahul
rahulangal is on a distinguished road
In fluent For pressure inlet B.C. two Inputs are required,
1. Gauge Total Pressure.
2. Supersonic/Initial Gauge Pressure.
What atre these two pressures physically???
rahulangal is offline   Reply With Quote
Old   July 4, 2010, 04:58
Hessam
hmirgol is on a distinguished road
Send a message via Skype™ to hmirgol
for the schematic attched, which boundary condition should be implemented for the bottom and top of the cavity
Either 2D and 3D modeling is desired.
Also the aim is at Natural Convection in this cavity filled by Air.
Does it make any sence to use the inlet and outlt pressure B.C.?
hmirgol is offline   Reply With Quote
Old   July 4, 2010, 08:17
Ali Jafarizade
jafarizade is on a distinguished road
no it makes no differance to use inlet or oulet pressure B.C. But for the lower boundary if you use Pressure Outlet you will see reverse flow and you should set the reverse flow characteristics.
jafarizade is offline   Reply With Quote
Old   July 5, 2010, 04:27
Default thank u....
Rahul
thanks for replying my question.... but i have to use the pressure inlet bc at any location not specifically @ natural convection... as in my problem i want to simulate a crack in high pressure pipeline, i don't now the velocity their...
like a hydrogen carrying pipeline at pressure 11 bar & dia 1m has crack of 20cm & i want to simulate h2 release from crack... but i don't know the exact velocity over there so i want to use pressure inlet BC the rest of pressure is atmospheric so how cud i use pressure inlet bc????
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 22:32
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
Pressure Condition sidd Siemens 0 April 2, 2007 10:31
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
Pressure inlet definitions Christian FLUENT 0 April 15, 2003 08:24
